Z5 premium dual simple ringtone setting missing
BEJOYS
Different ringtone for dual sim setting missing after mm update
93 REPLIES 93
wilsondaniel924
That is tagged as a 'solution' - thats not a solution Rickard! Its a copout! Tell Android your customers are demanding the feature be re-instated! The customers that ultimately keep you employed Rickard!
Cheesfest
Hahahah Grinning_Face
This is so funny Slightly_smiling_Face
So - at first you (Sony) has created a crappy dual SIM product (my D6633 / Z3 Dual) in which:
- dual sim is not working at all - any combination of "phone call on SIM X and internet on SIM Y" causes that there is no internet Slightly_smiling_Face This is just a big laugh at dual SIM philosophy Slightly_smiling_Face and at specs presented in manual.
- a popup with choice of which SIM should be used fo call is often not showing
- device often drops cell network connection saying "network unavailable" and then it shows full signal power after 5 seconds, but then disconnects my call again after half a minute and so on, despite I am just sitting at my desk in the office.
This was happening on 4.4, 5.0 and 5.1. So, I have sent this "device" to your service center. And I got it back with Android 6.0. And now you are informing me, that "in Android 6, it's no longer possible to set ringtone to your second SIM card. This is a limitation on platform level from our platform supplier"? Is this a joke? At first Sony has sold broken phone, and then it repairs it in such way that it misses most elementary setting because of "limitation on platform level from our platform supplier"? Then change your supplier! Why other vendors can have Andoid 6.0 dual SIMs and still can allow for choosing separate ringtones and Sony can't?
How dare you to say such nonsense? Then maybe you are going to invent Sony Z7, which will be unable to support cell phone network because of "limitation on platform level from our platform supplier" and it will work only with Wi-Fi and USB cable? How about Z8, which will be able to communicate only via sloooow MTP through USB and will be used only for making photos and playing music? You can also put on the market Z8 Dual. Which will support dual SIM cards just for a joke, because there will be no setting for ringtone at all, as it would work only communicate with poutside world via USB... Pathetic. My friend has right saying "Buy OnePlus2 - more cores, more RAM, same other specs, less money. And a dual SIM too." And I was so stupid to not listen to him...
Eeettt
I've Sony Xperia Z3DUAL and me too have the same problem
I can't set different ringtone for each sim card and it's too annoying please solve this problem and weakness as soon as possible
bews
Still no fix? Will this feature be available in android 7?
Andrey-spb
Z4 Dual D6633 have the same problem!
Nino_Quincampoi
Is there someone from Sony reading?...
Vito72
The same problem for me. Which is the solution?
Nino_Quincampoi
Up... Slightly_smiling_Face
Nino_Quincampoi
Hope this will be really solved with Android 7 in december otherwise, bye bye Sony!!!
Nino_Quincampoi
Nos that Android Nougat si arriving, does the dual SIM ringtone is back?...
