Hi
I bought Sony xperia z1 before more than one and its working correctly and after update phone to android 4.3 in the second day after updating suddenly shut down and I pressed on/off bottom it was booting until android page and shutting down and I removed sim card same problem I tried to connected to wall charger and press volume up and on/off bottom its vibrate and leave it charge for more than 2 hours and after the charging ats booting until android page and shuting down I dont't now if its software problem or hardware
Thanks
Connect to wall charger,force restart(power button+vol up until the phone vibrates).Let it charge for 2 hours.If this does not work,after 2 hours repair with sony update service.
http://www.sonymobile.com/gb/tools/update-service/
Yes,the phone needs to be off to repair with sony update service.
and I would like to add the battery show not charge after I charged and bottind and shut down after that
Do you have at least 60% battery?
no its not charging after 2 hour the battery shows not charging and its vibrate and booting until android page and shut down
And if you connect to wall charger,nothing happens?
and if I connect to wall charge the sony and xperia sign appear and booting and red light above ans disappear after that and vibrate and show battery one line charging and shutting down
And after you connect to charger,can you press power button+vol up until you feel 3 vibrations?
