Xperia z randomly does not wake up for a minute or so!
saabuldin
Recently in the last week while using my xperia z, when I press power button, it goes to standby and screen goes off. But as I press the power button again, it does not wake. It still runs and I get messages and notification led works but screen does not come on. I keep pressing power button and after about 30 to 60 seconds the screen comes on again. What could be causing this problem? First problem since the sudden death glitch.
profile.country.RO.title
_alexdon_
Ok,better send them the phone right away.
alexdon
18 REPLIES 18
_alexdon_
Boot your phone into safe mode,see if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
alexdon
saabuldin
It did the same in safe mode. Other thing I noticed is if I press power button off and on at lock screen then iI works fine. But as soon as I unlock screen then turn off. It won't come back on until after a few presses and about 10 20 seconds.
It also mostly happens at night when I'm in bed using my phone, could it be caused by the phone heating up.?
_alexdon_
Strange.It means no 3rd party app should interfere.Do you have,by the way,any task killers or battery savers?
alexdon
Danial-mach1
Leader
I think it's firmware issue
Cause other users reported this... Also we got this on our last sw on sp
If software Repiar didn't solve it then it's firmware issue
saabuldin
No. I don't believe in them. All I use is stamina mode.
saabuldin
Does that mean we have to wait for Sony for the fix
_alexdon_
Do you have the option for power button to end call?
alexdon
saabuldin
I did have. Since new firmware I haven't checked. Where would be?
saabuldin
Found it. Yes I do have that option
