Xperia Z - No Sound on Calls
daalig
I've just purchased a new Xperia Z today and as I brought it home and tried to call someone, they couldn't hear me and I couldn't even hear them. I can't even hear the ringtone when calling. They receive my phone call fine, but getting no sound.
Done a factory reset and a Repair through PC Companion but still not working. SMS works fine, so my sim/network seems alright. My MIC is working with Google Voice and sounds are coming out the device when I play music, so the speaker and mic seem to be in order.
Call Settings/Sound settings seem to be correct, I thought it was the obvious that the Mute Button was on but it isn't. I feel like this problem will be simple to fix but nothing works. Reinserted the Sim Card aswell. It seems more like a software problem since the Speaker and Mic are working correctly, just not with phone calls. Would the Sim Card be no good for calls but fine for SMS/Internet? I don't have another sim card to test that out.
I've tried using the headset/mic combo to make calls, that doesn't work either, and putting calls on loudspeaker doesn't do anything either.
Any help would be great. I've used Android for the last 3 years so I'm not new to the OS. It seems like no-one else has this problem with Xperia Z, I've checked every thread on here plus searched the net for a fix. I'm out of ideas 😕
74 REPLIES 74
profile.country.RO.title
_alexdon_
Settings-apps-all-chrome,uninstall updates.Restart your phone.It should solve loudspeaker issue.
alexdon
Tristan37
First:
thanks for the info, wouldn't have found it myself.. I'm hoping it works 🙂
So I should prevent Chrome from installation any updates, ever? Is there a way to disable updates only for one specific app such as Chrome?
Second:
I had some bad luck yesterday, I posted the no sound error disappeared on it's own , but now after a month or 2 it suddenly returned. Only problem is it's not consistent .. Sometimes I can hear phone calls just fine?!
Should I return it to the shop? They are probably just going to tell me there is no problem, or that it's fixed without checking it 🙂
And last:
It sometimes happens when using my data like H+ the feed just stops, 3G just isn't working anymore. When this happens I need to reboot my phone for getting it to work again. Very strange, seems to also be a software bug of some kind.
Anyone have the same issue?
Thanks,
Tristan
_alexdon_
You should not block anything,just remove the updates.Actually,a new update for chrome has been released,it should fix the issue.
alexdon
m4sterp
I've been having the exact same problem. For a while now my phone sometimes switches the speaker on for no reason when I answer a call. It hasn't happened recently, so it might have been fixed by the chrome update. The earspeaker still often does not work, and then when I switch the speaker on I do have sound. Sometimes I lose sound in the middle of a conversation, sometimes there is no sound to begin with, sometimes it works just fine. There doesn't appear to be anything wrong with the earspeaker as it works just fine when I test it in the service menu. What can I do?
_alexdon_
praveenminatour
I too have this bug.I recently updated my Xperia Z to latest android 4.4 kitkat after that only I got this same call bug but in 4.3 I had no issues my phone doesn't have warranty what should I do?? I can't find solution anywhere 😞
yvs080814
hi,
i've purchased Xperia Z, 8th of Aug 2014,
from the first day i've this problem of -No Sound On Calls-
Whatever i do i'm not getting this solved
only one thing helps me temporarily,
fast restarting my phone by pressing power button along with vol up button,
plz help me thru this , i've been a sony mobile user since the launch of your first models,
BimmerBarry
I just thought maybe we can find a common ground with any installed apps. Outside of the default
I have installed:
GO SMS PRO  -  use it
ADOBE AIR   -   don't use it
GOOGLE EARTH  _ use (once in a while)
GOOGLE MAPS -  use all the time
PLAY MUSIC - never use
VLC Player  -  use not often
YOU TUBE - use
FILE COMMAND - use
CAR DASHROID - use
Only apps I would think MAY do anything to mess the phone is DASHROID or GO SMS , Google Play??
Br0k3n
good day!
i would like to ask for help for my xperia z.
my problems are the following:/
1. After upgrading to 4.4.4 i experience is that i cant hear anything during a call and i need to use a headset or loudspeaker.
2. My loudspeaker randomly not funtioning, but in an incoming call the phone will ring.
3. When i will use Walkman and video streaming sometimes i cant hear the sound.
please help.
thank you.
tomasio
it dies at c6603 /w latest firmware installed. Crap. Never had st. like this on my old iphone 3g.
