i bought new xperia z1 on 28-01-2014 after updating it from android version 4.2.2 to new android 4.3 version after update my walkmen player is not working properly . there is a function called as sound enhancement after clicking it there is settings where we can select 3D surround sound but this sound enhancement is not working it shows a message that unfortunately sound enhancement has stopped .
please sony rectify this issue asap.
This is an issue that can be fixed by reinstalling the software with PC companion or sony update service.
thank you so much for the help . Now it is working perfectly
You are welcome.
