- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
I bought my Sony Xperia Z1 about 3 weeks ago and recently I have started having problems with battery life (since about 2 days). When I have received my phone everything was good with battery, I discharged the phone till it turned off and then charged it back to 100% several times. The problem with the battery that I have is that it dies pretty quickly. For example when I went to sleep one night the battery was on around 98% and the next morning I woke up it was on about 30% which is just ridiculous. Before the problems with the battery there battery only dropped down by 2%, and now it suddenly started dropping by 50% or more. I really don't know what to do, I was thinking about exchanging it as it is still on the warranty and also my father has exactly the same phone and he hasn't got any problems with the battery. So if you could help me somehow, if you can of course, because I don't want to exchange as it will take a while before I get it back.
Thanks a lot
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
My suggestion is to stay away from mcafee/antivirus, taskillers, task managers, battery apps, ram apps, booster apps.
it might be a good idea to
Repair your phone
Bridge (for Mac)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Check which apps are draining your battery
settings > power management > battery
also check the graph
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Here are the screenshots of both thing that you wanted : )
https://app.box.com/files/0/f/0/1/f_11184324576
https://app.box.com/files/0/f/0/1/f_11184321300
Thanks for quick reply
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
that isnt a direct link mate.. i cant view it.. you have to share it and allow the premisions for anyone with the link then share that link.. this one says no access.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sorry,
https://app.box.com/s/hj963ji5a0pqrgzirjs7
https://app.box.com/s/rhy0xs890li5lps90tna
Is it working now ?
// Changed the link, both of them were same, should be good now !
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You have to make the files/pictures public
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
it seems that indeed there are apps using your data and/or wifi while Idle, you could check the list and see which apps are doing so
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thats a pretty reasonable graph for usage tbh... if you ask me your phone is operating fine...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ill upload my graph shortly to take a look. i use it quite heavily throughout the day. with wifi and data at various intervals.. but as woolie said.. if you really want to juice the battery you need to turn off all the apps that run in the background using the data while your screen is off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The apps that are using my data (even though its off) are: Android System, Android OS, and McAfree Security. Not sure if that's what you were asking.
Oh, and also what does "idle" mean ?
