Recently I have encountered the problem that when I open Settings>Power Management>Battery Usage the Settings app closes with the message "Unfortunately, Settings has stopped". If I confirm with OK or just wait the Settings app will restart.
I have tried the following activities to solve the problem but without success yet:
What I have not tried yet is backup, reset to factory, restore backup.
Does anyone have an idea how to be able to see battery usage again without resorting to a factory reset?
Try settings-apps-all-look for settings app,tap on it and clear data.Restart your phone.
Thank you alexdon.
Unfortunately that didn't do it either. The settings still close if I select battery usage.
There was another entry in the apps list just below the settings app, something like "settings memory" ("Einstellungsspeicher" in German).
Should I clear that entry's data as well?
Thanks for suggestions
In settings-apps-all,look for settings,it should be there,looking just like the normal settings app.There you can clear data for it.
Sorry alexdon if I didn't express myself correctly.
I did find the settings app where you pointed me to and cleared the data for it, but to no effect.
After the restart, the problem remains.
I was just wondering if i should clear the data for the neighbouring entry "settings memory" too.
Just for the record: It is a model D5503, Build 14.2.A.1.114, stock, not rooted.
Boot your phone in safe mode and see if the same occurs:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Ok,great.Anytime.
