When using any 3rd party media player, no matter if I am playing MP3s or videos, I don't hear any audio and there is some weird time skipping going on (timeline playback frequently speeds up so 2x up to 4x speed every other second, then goes back to regular speed, then speeds up again...).
I've tried PlayerPro, Poweramp and MixZing. All have exactly the same problem. The built-in Walkman app works just fine, but does not offer the functionality I want.
Current Build is 14.2.A.1.136 (Android 4.3). Got the phone just a couple of days ago and already have such problems - very frustrating.
Is there anything I can do to fix this (except returning the phone and getting a different model)?
I searched Google for this problem but didn't find anyone having the same symptoms. Considered trying this tweak:
http://forum.xda-developers.com/xperia-z/development/soundmod-purexaudio-v22-final-t2190558
...but it doesn't seem to be a very trustworthy source and I have no idea if this could even remotely fix the problem, so if I were to try this at all, it would be a very last resort.
Any hint is appreciated.
Okay, I have found the solution and here it is just in case anyone should encounter the same problem in the future:
As it turns out, the problem for the other players seems to have been caused by the Walkman app. Once no longer active on the system, other players like Poweramp or Player Pro no longer have problems with time skipping or muted audio. The audio is also no longer discontinued when the screen is off.
Why exactly this is I have no idea, but it works for now 🙂
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
This sounds quite strange. Do you have any accessories (like headset, speakers, charger) connected when you are experience this? Or do you experience this without anything connected too?
Have you had only one 3rd party music player installed in your phone and you are experience the same behavior?
Hi Alexander,
thanks for your reply.
No, I haven't tried installing only one 3rd party player at a time, will try that next - thanks for the suggestion.
In the meantime, I can clarify the symptoms a bit more since I could observe the behaviour more closely now:
I'll report back after testing with only one 3rd party player at a time.
Regards,
Markus
Okay, I did some more testing:
Additional observations:
Poweramp settings I've tried, to no avail:
I didn't see other settings that I thought might relate to the problem.
And to answer another of your questions: This is without any periphery or USB connection, just playing over speaker with no cables connected. I tried with a Bluetooth speaker once, but it did not make any difference.
This is getting stranger by the minute.
