Pl tell me is there IR Sensor, Landscape Mode in main menu and any stylus compatible like ZU
Pl tell me waiting for answers
Topic edited by Rickard
Z1 does unfortunately not have IR.
The launcher does support landscape but only when the phone is put in a docking station. If you want landscape during normal usage you need to install another launcher like Nova Launcher or similar.
Any stylus made for capacitive screens should work.
can we use any pen as stylus?????????????
The display in Z1 will not work with any pen or stylus. You need a stylus made for capacitive screens.
