The receivers always hear an echo from my phone, and the soud quality is bad.
I tried to change all the sound settings available, nothing works.
Anyone had same issue already ?
I have the exact same problem!! But I waite some time before I send it in. I am on my third Z2 right now because of various issues.
Greetings
David
I have an Xperia Z2 and i had the same call quality issues.
When i made or received a call, the other part listened to my voice with cuts and muffled.
Also when those cuts werent happening, i could hear hissing and connection noises.
This problem is normally caused by bad reception or interference, but i had full or almost full signal.
So after several tests i found some interesting things...
I decided to remove my official Sony book cover, and the the call's sound became clear with any cuts or hissing!
Now altought my calls arent perfect, they are much much better.
Meanwhile i replaced that book cover with a gel one and my calls are almost perfect.
However i still hear some noise but i believe this problem will be solved in an update that my phone hasn't received yet.
So i advise to do the following:
- Try the Diagnostic application that comes with the phone, and test your microfone with and without headphones (not a headset).
- Remove any cover you have and try to make a call in a place you have good reception. Listen to the sound quality.
- Connect a headset to your phone and make a call.
- Make another call with a headset but this time leave your phone on top of a table and don't touch it during the call.
- Also try to change the hand that picks tyour phone. Somehow i could hear slight change in voice quality when i change the phone from my right to left side.
I still have the same firmware version that has came with the phone. There is a newer one that has a "Enhanced in-call audio with fine tuned noise cancellation".
http://www.sonymobile.com/global-en/software/phones/xperia-z2/
I appreciate that someone with the same problems make these tests and share with us the results.
Thank you.
Omg Man Same things happend to me as u said.. i am using d6502 indian version of Z2.. i too have hissing sound during calls... sony service center failed to identify the problem
if i change the mobile to left side somehow the sound is clear..
Hi all,
I found something today regarding the echo issue. I got my replacement Z2. Made test calls, and it was ok, no echo on the other side. I did a restore from my previous backup and after that the echo issue came back. I did a factory reset, installed all the applications except one, viber. And now, there is no echo issue at all. I hope this can help a bit.
I have this mic issue too in Xperia Z2. And i also have problem when i connect bluetooth. Sounds is very low and i have all volumes high, i cant hear other side at all, always have to ask, can u repeat i dont hear you?.
Hope so sony fix this problems soon!!!!.. Or i change my phone other brand.
Hi...Just bought my Z2 four days back and everyone who calls me says there is a terrible ECHO sound... hv checked with the network provider there no issue from their end...will be going to return it today...I am very disappointed
hopefully this will get solved asap.
Before you send it,just check in call settings for microphone noise suppression.
