Hi there!
sorry for creating a new thread, can't seem to find the topic that fits my question.. and am just a new sony phone user..
anyway, here's my question..
Is it alright if I charge my SONY Xperia Z phone even if the it doesn't have low battery yet? anywhere between 30-70% of the battery.. If I do charge it having 30-70% battery, will it cause damage to my phone/battery??
thanks a lot!
You are not going to damage your phon, you can charge it when its at 99% or when its at 3% or 50% etc, you get the idea
so you mean, it won't have any effect on my battery/damage my battery if I do so..
okay, got it.. thank you for your answer and time!
Anytime
