I just got my Xperia Z1 and it seems pretty awesome (at least for me) but there is only 1 thing that bothers me most
when I go to Settings>Power Management>Battery Usage, my screens using 60~65% of the screen and the rest is <10% so technically speaking it drains so fast!! is this normal?
Here's what I did so far and if someone can come up with other solution please do help me or do I need to send this to my mobile service provider for replace?
-all the stamina section has been enable
-Settings>Display all disabled including x-reality
-wallpaper is black (means no wallpaper is applied just to isolate the issue)
if I miss something please do help me and thank you!
Hi pingckoy
i know what it feels when you buy new phone and its doing weird than we expect ;), so the problem you are facing is normal, since it is new phone it takes few time to come on track so be calm
>about background wallpaper, yeah it absorbs some battery usage but not too large, so you can add wallpaper without any issue
>my phone battery did the same thing after doing update, so by reading one of the blog they suggested to charge the phone for whole night!!(just once), so before going to sleep i drained battery for 5% and charged overnight, morning woke up and restarted the phone, then it goes no battery problem from there, i can manage my phone for 2 complete days without any problem, and end of 2nd day i still left with 40% for charge, make sure dont charge the battery for complete 100%(i prefer doing this) i charge it for 90s or 95%.
let us know
Manjuboyz
NOTE:
Rate me(Kudos) If you are happy with my Resolution, Thanks
Hi pingckoy
let us know
Manjuboyz
NOTE:
Thank me after it works until keep us updated, so that we can find solution for this
but the suggestions what I gave is Genuine, which is from my phone:)
Manjuboyz
NOTE:
