Battery notification light goes off
paul_ashis
For the first time power on my z1 I charged it 12 hours. First shows orange light then shows green light. Approximately after 10-11 hours the green light goes off (none of notification light shows) but my phone was plugged in to a electric socket. Is that any problem happens with my handset? Please give suggestions.:smileyconfused:
profile.country.RO.title
_alexdon_
Overcharging does not affect the battery(these batteries do not charge after they reach 100% full charged).But it is recommended to disconnect the charger after reaching 100% full charged.
alexdon
7 REPLIES 7
paul_ashis
But my Z1's battery notification light problem is something difference:smileysad:
_alexdon_
I know,but I thought you could find something helpful there.Try and force restart your phone(power button+vol up until the phone vibrates).It should not turn off.
alexdon
paul_ashis
okay. Is that happened for over charged (12 hours) the phone?
_alexdon_
I have not seen this before,I do not think charging that much could be the issue.Have you tried contacting sony about it?
http://www.sonymobile.com/global-en/support/contact-us/
alexdon
paul_ashis
Not yet. Thanks for the suggestions. I will contact later.
Last thing is that, over charged the battery can be harmful for the handset or the battery?
_alexdon_
alexdon
