XZ PREMIUM DISPLAY
David_36
XZ PREMIUM DISPLAY
Because I can not choose the 4k and leave the device asin and then put it back in 1080 as it does Samsung users choose Sony can not, correct that and the vulturicity of the loudspeakers 🔊 sounds very low
GT
2 REPLIES 2
profile.country.PL.title
najodleglejszy
what build version are you running (Settings > About phone > Build number)? the latest is 45.0.A.7.90 and it seems to have increased speaker maximum volume a little.
David_36
Slightly sounds more but still low, also noticed less yellow in some night shots, but even so the terminal is limited, the screen does not use its maximum resolution and does not give you obsession to change it yourself from the terminal like other companies , It is something that should be implemented through software and that each user decides how in which resolution to fear the screen
