EX750BT not working well with my XZP
iNOZOMIPOWER
So I am using EX750BT with my new XZP (G8142) 45.0.A.5.1. However the volume control of the headphones is broken when using it with the XZP. The first level and second level are relatively quiet, but then the third level is so loud that it hurts my ears... The volume control on the headphones and the phone itself is also synced (If I increase volume by pressing the button on 750bt the media volume shows up in the system and goes up as well.)
Is there any way to fix the huge jump from 2nd level to 3rd level?
If not is there any way to separate the volume control? (On S7 Edge, XPS13, etc, the volume control on the phone or computer is separated with the headphone volume control. That means pressing the volume button on 750bt won't change the system volume of the XPS 13 or S7e)
The other two devices I mentioned don't have any problems with the volume control. Every level is a smooth increase.
0 REPLIES 0
