front camera says 15MP instead og 16MP on my XA Ultra when i check the settings for the front camera
it is normal or it should be exact 16MP for the front facing camera for XA Ultra?
Thanks!
There's no built in feature where you can record a video and play it back in slow motion, but there may be such an app available on Google Play Store. Have a look there to see if you can find an app for that purpose, but note that I can't assist you with any third party app.
Okay, Thanks
If i will have any inquiries, i'll let you know.
Thanks Emir for the help
Cheers!
Cool, that sounds good! :smileysmileythumbsup:
