Hi @Omar16,
I'm sorry to hear about your phone.
Have you had the time to try your phone in safe mode that @uliwooly recommended? If so, did you experience the same behaviour when making a phone call?
If you did, I would recommend that you change the preferred network type in your phone and see if you are able to hear the noise when making a call with GSM only.
Go to Settings > More > Mobile networks > Preferred network type > GSM Only > make a few calls and see if there is the same noise or not.
Let us know how it went!
