Hello,
I'm having an issue with the 12-tone analysis on music I bought from Mora. Albums I have purchased from there prior have analysed fine. But two recent albums refuse to, and SMC just re-attempts to analyse them on each start up. (In the past I've had SMC say the tracks were analysed, by then on my A55, it'd show that actually, they weren't. And because of this it would not re-attempt).
The problem is, I could use the built in option to convert the tracks to FLAC again, and this would then allow the tracks to be analysed, but they would no longer be 24bit FLAC.
The logs for SMC are full of entries like below:-
MediaCenter.log
[2022/09/14 11:21:52.431] [ERROR] <renderer> | media-manager:common:diagnosis audio:[id:1ywQeBSNe2jNEGR8, prop:album] clapped detection.
Media-Core.log
[2022/09/14 11:40:43][226C] [E:0x80040402][F:z::internal::ObjectBase<class z::IDivide,class z::internal::DivideImpl,0>::CHECK_OBJECT_CONDITION][L:93] : this object already disposed.(generic fatal error)
[2022/09/14 11:40:43][226C] [E:0x80040402][F:z::internal::ObjectBase<class z::IMigrate,class z::internal::MigrateImpl,0>::CHECK_OBJECT_CONDITION][L:93][Win32(Last Error):1400] : this object already disposed.(Invalid window handle.)
[2022/09/14 11:40:45][226C] [E:0x80040402][F:z::internal::ObjectBase<class z::IDlnaDms,class z::internal::DlnaDmsImpl,0>::CHECK_OBJECT_CONDITION][L:93][Win32(Last Error):1400] : this object already disposed.(Invalid window handle.)
[2022/09/11 18:15:59][680C] [E:0x80040402][F:z::internal::ObjectBase<class z::IAudioConvert,class z::internal::AudioConvertImpl,1>::CHECK_OBJECT_CONDITION][L:93][Win32(Last Error):183] : this object already disposed.(Cannot create a file when that file already exists.)
Can anyone help?
Hi AMoonRabbit, is this related to any Sony device? If yes, please post the model number and a better explanation on how the issue is related to the device.
This is related to Walkman devices that support SensMe Channels, it's not hardware related but an issue with the PC software. If there's a dedicated section for the Music Center application please move the thread there.
Sony music center is failing to generate 12-tone analysis data for music I bought from mora.jp.
