I bought walkman,mp4 NWZ-E453.
I saw that player can turn on-press any button.
I don't like that.Can I change that?And how?
Hi annaBG,
Unfortunately there is no option to change the way your Walkman switches on.
The only thing I'd suggest is that there is a 'Hold' switch on the right-hand side of the Walkman which prevents all of the buttons from being operated, for example when it's being carried in a bag or pocket. If you slide this switch over it would at least prevent the unit from being accidentally switched on? Hope that helps...
