Wireless problem
rozy
Wireless problem
I have just purchased a pink sony vaio lap top for the wife problem is i cant get the thing to connect wirelessly to the internet. it can see the wireless network but when you put the password in it says "wireless authentication failed because of a timeout" can anyone help please?
2 REPLIES 2
Blencogo
Hi rozy and welcome to Club Vaio,
Does it connect using a network cable?
Does it connect if you turn off all wireless security?
Some routers give this problem with Vista - what wireless router are you using?
For other models, updating the wireless network card drivers seems to work.
Please reply and give the information requested and I'm sure someone will point you in the right direction.
:wink:
rozy
Yes it connects using a network cable
The wireless router is a netgear DG834 Router
The vaio works wirelessly on my works network
