Wireless Problem on VAIO VGN-NS10L/S
davteal
Having a problem with my new Vaio wireless connection. The wireless connection does not work when I boot up first time. If I restart the machine is usually works 2nd time or if not I can sometimes disable and then re-enable the adapter to give it a kick. It is a Atheros AR928x wireless network adapter running driver version 7.6.0.114 27/4/2008 also running Windows VISTA?
0 REPLIES 0
