Wireless Aerial for XL302
looski
Hi everyone. Does anyone know what the part number is for the wireless aerial to suit the VGX-XL302 - or what type of connector it is so I can buy an after market one is spares are not available..?
Looski
4 REPLIES 4
Thalamus.
Champion
Hi looski,
it may be worth contacting Nexttronics, they may be able to supply the part you require, use the following link to view: Nexttronics site
GavMack
The wifi uses a standard reverse SMA connector so any aftermarket antenna rated for wireless G will do the trick for under a tenner on ebay.
thornsdale
But don't forget the antenna has a left-handed thread!
rybles
Hi - just wanted to pick up onthis thread as I have a similar issue - I am in the UK and have found a supplier to provide a 'standard reverse SMA connector' but when I mentioned about the left handed thread they were not sure (this reference to the left handed thread was posted after your post in this thread)
Any advice appreciated
thanks
David
