Hi is there anywhere i can download Sony drvers without downloading other junk virus's etc
Sony dont provide this driver?
No drivers on my c drive.
Would cost about £40 to get the recovery disc from Sony asia.
Driver for a Sony Vaio PCG-GRT30P for XP
Audio driver not provided on the sony website= SigmaTel STAC9750/51 @ SiS 7012 Audio Device PCI
This driver info comes from everest
I have tried driver detective and all this does is bluescreen part way through the driver install, so i guess its the wrong driver for xp (it picks realtek WDM_A406)
I have done about 3 fresh installs with xp, no service packs, xp sp2, xpsp3 and win7 32bit to test the sound drivers (win7 does work with the realtek audio xp driver, but its too slow with win7 i would like xp on this laptop)
Thanks for any help
Hi marcusrolyat,
As this is a Sony Europe forum you will not find drivers for your particular model here.
There are similar GRT models listed on the European support site that have the SigmaTel STAC9750 chipset and you could, at your own risk, try these drivers that are available as both original and updated.
http://www.sony.co.uk/support/en/product/PCG-GRT715E/updates
Rich
Hi marcusrolyat,
Rich
Hi Rich go to the top of the class, you deserve a medal, that driver worked the first time. I hope others needing this driver stumble on this thread.
Thanks Marcus
You're welcome Marcus
THANK YOU,RICH!!!!!!!!!!!!!!!!!!
IT WORKED ON MY "ANCIENT"NOTEBOOK SONY VAIO PCG GRT 55F/B!!!!!!!!!!!!!!!!!!!
I COULD NOT FIND IT ANYWHERE............
IT (AND YOU)SAVED ME.............
OBRIGADO(THANKS IN PORTUGUESE)
quitoBRAZIL
Hi quitoBRAZIL,
It’s good to hear that this old thread has helped someone else.:smileyhappy:
Rich
