WAN New modum Belkin will not work wireless? HELP
moneyman1
Can anyone help.I purchased new VAIO laptop. Have had internet connection with new Belkin modem via cable connection but cannot get wireless to work. It did for a short while but very very slow. re connected cable works fine. Have MS Vista. The signal strength is excellent. Any advice appreciated.
Thanks
1 REPLY 1
profile.country.en_IE.title
sonypass33
Delete and Re-setup the wireless connection.
IF that doesn't work, I presume modem came with a setup disc.
Start from scratch and use the disc to connect. (reset the modem first using the little hole on the underside)
