So i have a vaio VPCF11S1E/B and i have upgrade my windows 7 64bit to windows 8 64bit.I am using a razer naga gaming mouse so i want to disable the touchpad cause my hand touches on it and it makes it hard for me to play games like this.I used to be able to disable it from the vaio control center - mouse settings but now with the windows 8 the vaio control center doesnt have the disable option anymore.I s there any way to disable the touchpad cause it drives me crazy and i have tried to unistall it and everything but no matter it still works.
Thanks in advance
Chris
Hi Chris.
Have you reinstalled a Windows 8 compatible ALPS Driver?
Yes i have did that and it didnt work.still cant see the disable touchpad option at the vaio control center.
