i have a vaio vgn-nr10e/s just under 1 year old and the wireless has stopped working.
when i switch the computer on the led is on but goes out about 30 secounds later.
any one now whats wrong
thanks
Hi ellen.ellie,
welcome to Club VAIO..
Have you checked that wireless LAN is enabled in the Wireless switch setting utility.?
The Wireless switch setting utility should be found in the start bar notification area (next to the clock) on your task bar..
what does it look like im not very good with a pc
thanks
thanks
