VAIO SMART NETWORK STOPPED WORKING AND HAS CLOSED
drea.berry
Can anyone tell me how to rectifty this problem. I have only had the laptop VGN-NR21J for about 3 weeks and everytime I go on it I get this error message??? The error message goes on to say "A problem caused the application to stop working correctly. Windows will notify you if a solution is available" HELP!
2 REPLIES 2
Blencogo
Hi drea.berry and welcome to Club Vaio.
This error is often caused by trying to connect something like a mobile phone that is not supported properly by Vista. Unfortunately this is often a Sony Ericson!!!
I don't know the answer for sure but I would try re-installing the original version of VAIO Smart Network (1.2 - 1.2.01.13070) from here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&m=3061
If that doesn't fix it perhaps you should contact Sony Support as your Vaio is still in warranty.
:thinking:
drea.berry
Thanks Blencogo I'll try that
