profile.country.DK.title
alashou
Upgrade? NO WAY!!!!
This http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/103359  is BULL.
I´m happy and staying with 8.1
2 REPLIES 2
nicmeljones
I've just upgraded to W10 without a single problem. My Vaio is faster than ever. I'm so pleased with it that I've already removed the installation files so that I can't revert to 8.1.:smileyhappy:
alashou
My Vaio is sve14a3c5e
Restrictions on my Computer
Multi-touch gesture
The click pad, multi-touch gesture function is not supported in Windows 10. The multi-touch gesture setting will be disabled and removed from the VAIO Control Center during the upgrade process. This is applicable to systems that originally came with the multi-touch gesture function.
X-Reality
X-Reality is not supported in Windows 10. The X-reality setting will be disabled and removed from VAIO Control Center during the upgrade process. Affected models: SVD132 / SVF13N / SVF14N / SVF15N / SVJ202 / SVP112 / SVP132 / SVT112 / SVT212 series.
Extended Sheet Battery
The internal battery and external sheet battery status are swapped in the Windows 10 user interface display. This is a limitation in Windows 10, but does not affect battery functionality. Affected models: SVD112 / SVP112 / SVP132 / SVS13A2 / SVS1312 / SVS1313 / SVS1512 series.
Sony Sound Effects
Sony sound effects (xLOUD, ClearPhase, ClearAudio+, S-FORCE, VAIO Sound Utility) are not supported in Windows 10. The Sound Quality setting will be disabled and removed from the VAIO Control Center during the upgrade process. Affected models: SVD112 / SVE1112 / SVE1113 / SVE14A2 / SVE14A3 / SVE1412 / SVE1413 / SVE1512 / SVE1513 / SVE1712 / SVE1713 / SVJ202 / SVS13A2 / SVS1312 / SVS1313 / SVS1512 / SVT1112 / SVT1312 / SVT1313 / SVT1411 / SVT1412 / SVT1511 series.
2D-3D Conversion
2D-3D conversion is not supported in Windows 10. The 2D-3D conversion setting will be disabled and removed from the VAIO Control Center during the upgrade process. Affected models: SVL2412 / SVL2413 / SVL2414 series.
Near-Field Communication (NFC)
There are limitations between the NFC driver and Windows 10. NFC will not work in Windows 10.  Affected models: SVD112 / SVF14A1 / SVF1421 / SVF15A1 / SVF1521 / SVJ202 series.
Media Transfer Protocol (MTP)
There are limitations between the Media Transfer Protocol (MTP) and Windows 10. Users cannot copy or move any files from a USB portable device via MTP. It is recommended to use Mass Storage Class (MSC) instead.
Pointing Device Cursor
The cursor from the pointing device will freeze after resuming from (S3) Sleep or (S4) Hibernate. Affected models: SVS13A / SVS131 / SVS151 / SVZ131 series.
Restrictions on Sony Apps
Sony Windows Store Apps
Sony exclusive apps will not be visible via search or browsing in the Windows Store due to a limitation in Windows 10:
