tv tuner driver for VGC-V2M
DaveEboy
Can ne1 plz tell me where I can get the drivers needed to watch tv on my vaio.
I have the aerial input on my machine and windows keeps comming up with the found new hardware for the Multimedia Video Controller, but I cant find the driver needed.
Vaio zone used to show that the tv tuner was not installed but now i dont even get this, i just get pictures, videos and cds/dvds options, it does not show or give me the option to watch tv.
ne help greatly recieved, ty
17 REPLIES 17
jammold
@DaveEboy:
Can you tell me exactly what the problem description is, and what driver files (if any) are currently being used along with the version numbers?
If at all possible, if you can find the master INF (information and installation code) file, and reproduce the NT.Addreg registry section, along with references to the files, this would help, as I can ascertain from this how the drivers are being installed and provide further feedback.
It may be the case that an additional component driver or DLL is needed which might not be supplied, so the INF file is most valuable. If you have got a copy, I would be most grateful if you could reproduce in particular the files it references.
vaio-freak
You can always go to your support page for the model you own and download the zip file that should contain that driver.
mf_blues
I've tried all that and it doesn't work, I know what I haven't tried though, winding back the system clock and doing a full factory restore. That might do it.
Before you start laughing there are many programs out there that get screwed up by the date. APC Powerchute for instance recently went bananas over July 26th and started denying access to windows terminal servers, wind back the date, update the software and jobs a good one.
Might try it later but fed up of restoring every five minutes right now.
profile.country.en_GB.title
kee-lo_
Yes it's important you have the correct time and date
mf_blues
Tried winding back the clock still didn't work, have contacted sony but no response yet.
No TV tuner, can't create restore disks, games keep blue screening. (Just ran a memory test today for about 4 hours without any problems so it must be the drivers but which ones, I keep upgrading all of them and it still crashes.)
I'm beginning to think I've been sold a right bag of Sh!te.
Surely Sony know about this problem, why won't they sort it out.
jammold
Have you tried cleaning your fans in this computer? Use compressed air whilst the unit is offline to remove dust and debris, this will reduce the temperature of the unit, and ultimately fan noise and increases stability.
Sadly Sony seem to be pretty cr4p for driver updates. Have you tried the non-OEM (i.e. Nvidia/ATi etc) graphics drivers instead?
The trick here is to remain very patient with Sony, as difficult as it is, because if you assertive (not rude or aggressive) they will often escalate the case further. Just keep on their backs until something gets done.
mralexnewman
There are a few people on this forum, including myself with a very similar problem with the TV tuner. Sony e support say that it is a hardware fualt with my PC, but reading the forum makes me think that it is to do with softare, as occasionally I do get an "unknown PCI device" in the device manager, that simply wont install, yet I know it is the SOny MPEG REalTime encoder board.
irabeach
is there a solution yet for this problem? do i need a new driver and where do i get it? all the sony updates will not work...
