Hello.
A couple of weeks ago i bought a Sony Vaio VGN-NR31E/S.
Internet with cable works fine, but there is a little problem when i shall use wireless internet. There is a little button on the front of the computer that says WIRELESS LAN and ON/OFF. But when i press "ON" the lamp wont light. It will only light for a little while when i start the computer, but then after a little while it will turn off again.
What is the problem?
Hi Chiim,
welcome to Club VAIO..
Have you checked that wireless LAN is enabled in the Wireless switch setting utility.?
The Wireless switch setting utility should be found in in the statrt bar notification area (next to the clock) on your task bar..
it worked now
tyvm!!
You're welcome..
