I have a 2 month old VAIO FW21E with VISTA Home Premium preinstalled. For converting of music to mp3 etc. I use Sonys application Media Manager for WALKMAN 1.2 but for some reason windows switch it off immediately after I try to start it. Windows intorm that A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. I have tried to reinstall it twice without luck. Surpricingly I try to start it again for two days ago and it worked perfect but now again same problems.
Same thing happens also now to a Sony pre installed program AML (I,m not sure what this will do) at computer start up, as a temporary solution I have switched it off from starting up procedure now. Can anyone help me with this problem?
