- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sound problem Vaio VGN-FS215S
Hello,
I have a problem with my Sony Vaio VGN-FS215S. The problem is a kind of “bad contact”. When I use headphones only the left one works. I have to move the jack a little so it gets a good position and both sides have sound, but this doesn’t always work. Usually I have to put a piece of paper under the jack making some pressure in up direction searching for a good position so both sides can have sound.
I have tried different headphones and always happens the same. The speakers are working fine.
This problem happened suddenly, the laptop didn’t fell down neither suffered any accident.
Thanks in advance to anyone who can tell me the source of the problem or any solution to it.
Best regards,
Luís Martins
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi you have 2 ways of fixing this
1. get a small pointy object (same as a needle) and try to putt the contacts out slowly on the inside of the connection.
2. take the base of the laptop and then using a pen/pin bush the connectors down on the connection.
both do the same thing
