Sony VGN-FZ11M XP installed few remaining problems, Help pls
Twinklesony
I bought a VGN-FZ11M and downgraded from Vista to XP Pro. It took a time to get all the drivers and get XP to work properly. Related threads were a big help in getting the required info, which I must add all worked fine :slight_smile: , eventually apart from a couple. If everyone complained to Sony maybe they would be forced to create specific drivers for this model.
:devil:
The couple of items not working, which I would appreciate some help with are, 1) The motion eye web cam, which does not seem to work with its driver (vgp-vcc4). 2) When head phones are inserted, the sound driver does not transfer the sound completely to the headphones. Instead the sound is played through both simultaneously. 3) No volume bar appearing on screen when using the volume up/down button. 4) Driver not allowing machine to go into standby.
Please help with any ideas and drivers
Thanks in advance. :wink:
4 REPLIES 4
_eXplorer_
Hi, please, i try to install xp to FZ21m, but I didnt find any working driver for sound card, please if you have it, could you refer, where you found it? Or can you send it me via email... thanks a lot my emial is [email protected]
Thalamus.
Champion
Do any of the FZ19 XP drivers HERE help..?
Twinklesony
Thank you for the pointer to these FZ19 drivers, but I have already tried these, 90 % of my working drivers/utilities come from the original installation drivers from Vista, apart from Audio, Graphics, Web Cam, Host controller and Processor. Still these couple of problems exist.
Thank you
organico
hi.
where can i find a website with this XPcodes for the VGN-FZ11M ?
and be sure there's nothing left?
