Hi, the wireless on this machine has been working fine until today. I have the switch on the front of the machine set to wireless and when booting up the light stays green until almost completely booted into Vista, then the light goes out. Diagnostics say to ensure the switch is set, which of course it is. If I access Control panel/windows mobility, it shows wireless as off, but the icon to switch it on is greyed out? I had something similar before where the light would not come on and I used the toolbar which came pre-installed at the top of the screen to restart wireless, but this toolbar has vanished.
Does anyone know how to get this toolbar back, or what it is called?
Or any ideas on how I can get the wireless working again? The router seems ok, and works with wired lan which I am using now. Also the PS3 works wirelessly.
