Good day everyone!
English is not my first language so I apologize for my grammar mistakes.
I have purchased the sony fw11sr with Vista Home Premium 32 bit, and reinstalled a new version of Vista Ultimate 64 bit. I downloaded and installed every drivers from here http://support.vaio.sony.ru for vista windows.
Now, I got some miss driveres (at device menager there are 3 devices with unkwnonw type) and also i can't set brightness with keys Fn+F5 or Fn+F6 (merely it does not work!).
Can anybody help me?
(for russian)
Добрый день всем!
Вопрос номер раз, почему я попал на англоязычный форум выбирая при этом странну Россия?
Это что, новый способ издевательства?
Далее строго по вышесказанному. Купил ноут ony fw11sr with Vista Home Premium 32 битная версия. Переустановил на 64 битную и приехали, не определяется три устройства и не работает регулировка яркости.
Означает ли это что для данного ноута (имеющего архитектуру 64 битного процессора) до сих пор нет самых простых драйверов для клавиатуры под 64битную версию виндоус виста?
И второй вопрос, что делать?
Good day everyone!
(for russian)
Добрый день всем!
Thanks for links.
I tried to use the drivers (from links) for similar model (fw148,fw190, fw292 and some others for 64bit Vista) but it is not work on fw11 😞 .
I can't understand, what is wrong and what i have to install to make functionality of fn+F5 and fn+F6 keys. For instance, the fn+F2 work properly, it displays the symbol of nosound and turns off the sound. But there is not any action on fn+F5 or fn+F6 (nothing displys on bottom). 😞
Thanks for links.
This worked for me (posted by jastababe on fixya.com)
Not all things will be available to you, but enough will.
t seems like people are having problems with getting the Fn Brightness and CD Eject Keys working when installing XP.
The following files and install method works here:
01. Install SFEP [AR51] (Right Click - Install SonyNC.inf)
02. Install Sony Shared Library [AR51] and Restart when prompted
03. Install Sony Utilities DLL & Settings Utility Series [BX4]
04. Install VAIO Event Service. Select Custom and Check VESUnique and Sound [BX4]
05. Copy AR51 Vista VESConfig.ini (from attached zip file) to folder C:\Program Files\Sony\VAIO Event Service
06. Start - Run services.msc
07. Find Vaio Event Service in the Services list and Restart the Service.
Your Fn and EJECT Buttons should now work.
With regard to the unknown items in Device Manager, one is likely to be the camera and another maybe a network controller. Try the manufacturer's sites for 64 bit drivers.
Thanks to all!
So what you are saying is that only the brightness keys aren't working?
Yes! I did it!
I find that the SNC sometimes called as SFEP.
So i downloaded the SODSNC-14376700-64.EXE and unpacked (i used uniextract).
Now it works and I'm happy!
Here is the pure driver of SNC for fw11 vista64.
Glad to see you got things sorted out. Well done
