Processor Speed Problems on S3XP
simon.giesen
Hi everybody,
It's so hard to tell my S3XP that I want to have full speed, 2GHz.
Every energy saving option I have tried and nothing worked
properly. What can I do? I tried to re-start my computer several times and it worked somehow. Any help? Is there any possibility to turn off the speed step option? Any software?
3 REPLIES 3
GBS
Speedstep XP will solve your problem, you can set it so the processor can run "Dynamic Switching" , "Max performance" or "Max Battery". On my K115Z this is either 3.06GHz or 1.06GHz.
Download Here
Good Luck
simon.giesen
thanks for your help. I downloaded and installed the software. Sadly it was not possible anymore to do the "hibernate" when hitting the "power" button. Simply, it was not available in the windows dialog. Afterwards I had to deinstall the software - and this solved the "hibernate" problem. But: The software didn't help at all, I am afraid. Any other ideas?
Nico_801
I've got the same problem with S3XP's VAIO Power Mgt and reported it on e-support about one month ago. So far, they havn't come up with a solution.
