I recently bought Sony Vaio VGN-CR42S-L and installed Windows XP on it because I don't like Vista.
I am currently missing drivers for:
- Audio
- Bluetooth
- Chipset
- Graphics
- Pointing Device
- Wireless
the most important ones are obviously audio, chipset, graphics and wireless.
Please help me.
Hi krigath and welcome.
The only XP drivers I know are for the CR3* Vaios. Some may work with your CR4* Vaio but at your own risk: -
CR3* XP Drivers
You will not get everything to work properly with XP, it is not possible for this model which was designed exclusively for Vista. Personally I prefer Vista and everything working perfectly.
Thank you very much.
What is the reason that you prefer Vista? Only driver compatibility or something else?
Also, I am still looking for a Wireless driver, this one wont install.
SOLVED!
