Hi, I have problem with my screen in my vaio. From some time when i power on laptop screen is purple/pink at starup and the same its happening when I switch off screen/power saver screen is purple for about 10 s and after that its getting back to normal color. Anyone Know what is happening with this??
Thx
But how to make sure what causing this?
I suggest you either contact Sony Vaio support, you can do this either by phone or via e-Support, use the following link to find the contact details: Sony Vaio Support
Or
See if a local repairer in your area can give you an quote for repair, then depending on the cost involved with repairing, decide whether you can live with pink start-up and shutdown screens..
Screen statrs flashing now
How can I check if its faulty screen or sys board??
Screen statrs flashing nowHow can I check if its faulty screen or sys board??
On external monitor is OK so I think I will order new screen. I supose that Sony won't help me with that and I'm able to replace this sceen by myself.
OK its like that now:
When laptop is ON screen is not working at all now but if I unlug cable A and plug it back in screen is working perfect for about 2-3sec and you can hear buzzing from B. I thing that it might be faulty or cable A, or this green peace where cable A is pluged in(don't know what is name of it) or faulty screen.
See picture below.
http://img513.imageshack.us/my.php?image=dsc00509pv9.jpg
See picture below.
I've replaced LCD today and its perfect now
:smileygrin:
Thx for help.
I've replaced LCD today and its perfect now:smileygrin:
Thx for help.
Glad you have managed to fix your problem..
