I'm using Vaio FE21H from past 18 months. A weird problem started recently. Here is what is happening.
- While booting, a continuous beep is heard as if some key is pressed. I have to press the Esc key to continue with the booting process
- Once it reaches the login screen, some character keeps appearing in the Password textfield. Apparently, it stops once I start pressing the backspace. Then it allows me enter my password.
- After windows has started, I see that "m" key doesn't respond and also "Left Shift + 8" doesn't work.
- sometimes it so happens that "m" key press responds after a very long time.
This problem re-occurs in the same sequence every time I boot the OS (even while starting after the laptop being shut for days).
Could anyone kindly advise on the problem and any resolution.
Thanks
Sharath
