power issues
tazzyboy
power issues
hello all, can anyone tell me if leaving the ac adaptor plugged in when the battery is fully charged can damage it,or does the computer switch to ac mode automatically? have heard lots of different stories and am not sure what to believe i have vaio model VGN-NR38E Thanks for any info.
4 REPLIES 4
jumpsuit
Hi there
I would always unplug the adaptor if battery is fully charged,
or remove the battery when running from mains power as it can shorten the battery life
Thalamus.
Champion
Hi tazzyboy,
You may find the following links on How to prolong lithium-based batteries and If I remove the battery & run from a power source will it lengthen battery life? of interest.. :slight_smile:
tazzyboy
thanx for the info guys
Thalamus.
Champion
You're welcome.. :slight_smile:
