pointer problem
jgmtheo
pointer problem
Hi all,
New here. Can you help me with a problem?
Back clicks are performed ocassionally when just moving the pointer, ie without pressing the left hand buton or being over the back arrow. How do I over come this? Is it a trackpad problem or is it a settings problem? eg. I had to type this twice because I had to move the pointer to make a correction and it moved back a page and lost my post !!! Agh.
Thanks in anticipation for your help.
jgmtheo
4 REPLIES 4
Thalamus.
Champion
Hi jgmtheo,
welcome to Club VAIO..
Does this only happen when viewing web pages.?
If so your set-up may be slightly different but this may help..
Click on Start, then click on Control Panel.
In control Panel, under Hardware and Sound, select Mouse.
In the Mouse Properties window select the Function tab.
In the Function tab deselect Use Web Assistant.
Does that help with the Touchpad problem.?
jgmtheo
Hi and Thanks,
I have done what you sugested will go surfing now and see if the problem has gone.
jgmtheo
jgmtheo
Hi all,
Thank you, your solution seems to have worked find, I have had no problems since I followed your instruction.Thank you again.
Jgmtheo
Thalamus.
Champion
:cool: You're welcome.. :slight_smile:
