when i press giga pocket button the tv screen has the change channels greyed out so you cant do anthing
when i go into tv tuner all channels are there
if i renew giga pocket softwar it works fine but after re booting it has gone again can any one help please
pat
I have the same problem. It really annoys me: every time I re-boot the computer, the channels in TV-Setup are still there but I cannot click on the TV-button nor view a video. As you said: the icons are grey and not active. I have to uninstall and re-install giga pocket, then it works again.
Whoever knows a solution to this problem: I would be very very grateful.
Pascale
hi i have finally solved mine
in start programmes make sure
C:\Program Files\ sony\usbircs\USBsircs.exe
is allowed to start when comp is switched on
alternatively make a sort cut to the above on desk top and click on that before running giga pocket
it has worked perfectly for me
cheers pat
ps let me know how you get on
I have just had this problem, searched and found your post.
Yes it does solve the problem so thank you very much
for your advice.
It does however concern me that a company like Sony can
release a program with this sort of problem in it.........
Thanks Again
TimW
cheers pat
