No sound on my VAIO TZ31MN
aldarie31
Hello,
I have a very simple question: how can I get the sound on my VAIO TZ31MN? It tells me there's no sound device installed, but I don't know what to do. Can I have it installed without using the internet (because at the moment I don't have a connection)?
Thanks for your help!
1 REPLY 1
Blencogo
Hi aldarie31.
Are you still using the original Vaio version of the Vista operating system? If you are, you should find a fresh copy of the Audio Driver in the directory C:\Drivers\Audio or on your Recovery DVDs.
If not then you will need an internet connection because the Vista driver file is 16.14MB and can be downloaded from here: -
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&m=3078
:thinking:
