Hi @ all!
I'm wondering if I can upgrade my VGN-A417M to more than 1GB RAM. I know the manual says it's not possible, but I can't imagine why. Is it a BIOS problem?
Greetings
Silversandstorm
With the GRX model the quoted Sony Max memory was less than the MOBO chipset supported. Many people successfully upgraded beyond the Sony quoted figure.
With the GRX it was certainly not a bios issue
If you have an Intel chipset It may be worth doing some reading up on the Intel site.
Thx for your fast answer!
But what is a GRX model and a MOBO chipset? I haven't heard these words anywhere else. Please explain.
Don't worry about the details, If you look at the specs for your machine on VAIO-LINK it says it supports 2GB.
So its looks like you are OK anyway.
VAIO LINK A417M
Try Crucial.com and if you are keen why not investigate VAIO-LINK.
Just go to the page I gave you a link to and click on "2048Mb" IT WILL TELL YOU YOU HAVE TWO SLOTS.
Apologies M8 but all the info is on VAIO-LINK
It seens like the RAM on crucial.com doesn't work with the VGN-A417M.
And yes if you buy 2 X 1Gb you will have to remove the existing memory to fit it.
Yeah, that's true.
Thx! But there are only 512MB RAM available at sony. Are there 4 slots in my notebook?
Greetings
Silversandstorm
