Hello , I have VAIO PCG-Z1M , I wish to upgrade my slot memory ( now is 256 MB in slot + 256 on board ).
What is maximum of memory module in slot , user manual say 512 MB, but many dealers
say 1GB will work fine ! 1Gb will work or not,is it 512Mb really maximum or not ?
Thanks
Hi ivangara,
welcome to Club VAIO..
According to the Technical Specifications your Vaio’s Ram is upgradable to 1536 MB, use the following link to view:PCG-Z1M Technical Specifications
A large number of Club Vaio members have bought extra RAM from crucial.com an added benefit from buying from Crucial is their memory compatibility guarantee. To visit Crucial.com use this link: Crucial.com
If you need a guide on how to upgrade the RAM on your Vaio, then click the following link: How do upgrade my Vaio's memory ?
Hi Thalamus , thanks for friendly welcome
I was follow that link for PCG-Z1M Technical Specifications , but there they say only 768 MB (fixed 256 + 512 slot ) 😞
What do you think ,can I buy 1GB module SO-DIMM DDR1,and will then I have 1280 MB ?
Best regards......
Hi,thanks but..why you wouldn't recommend a 1GB module ?
Please ,anybody know is it 512MB module really maximum or not ? Can I use 1GB memory module or not ?
OK Thalamus ,thanks so much ......
Just last question, my old memory is 256MB CL2 , can I use CL2,5 ?
What is default for my Z1M .... CL2 or CL2,5 ?
Hi ivangara,
if you use the Crucial System Scanning tool it scans what RAM is currently in your Vaio and recommends a compatible upgrades..
Use the following link to access the: Crucial System Scanner tool
