anyone know how to set the vaio to alert you when battery charge reaching minimum? :smileygrin:
Hi tussies and welcome to Club Vaio.
Are you using XP or Vista?
You can do this in Power Options in the Control Panel. You also need to go to Sounds and Audio Devices -> Sounds and choose the most annoying and piercing sound you can find for "Critical Battery Alarm".
