Hi all!
Is it possible to add (an extra) harddrive to model AR11B in the spare slot next to the "C: + D:" original
drive, and if so any limitations or recommendations from all of You on the forum for how to do such a thing?
I have tried adding a second drive and it shows up in bios but not in "My Computer".
There is only the original "C: + D:" (80gb) disc visible..
If You have any thoughts on this thanks in advance for Your time!
Hi Marotos,
It is the same for XP.
