Help Viewing Ra304 on plasa screen
paulhadcock
Can anybody give me some pointers regards viewing whats on my monitor identically on my plasma at the same time. can do it individually. also need advice regards output to plasma as the image is realy poor. would very much appreciate any help.
6 REPLIES 6
chris_lewis
Hi, it really all depends on what input connections you have on your plasma as to the quality of your picture. which ones are you using?
C
Vas
You should be able to change the output resolution.
It's definitly possible with laptops but not too sure with the RA304.
Kee-Lo has an RA104, maybe he knows
I have VGA and DVI on my desktop and I can't connect an additional screen using both DVI and VGA. (I probably need graphic card that maybe enables this fuction) I could be wrong
Vas
Have you had a look in display properties for additional display?
I think this is due to the resolution
paulhadcock
C
obviously tv is a Sony but forgive my ignorance do you mean scart input, s video,RGB etc. there is no pc input with my model,only what i have mentioned, i overlooked that when i purchased it. is there no way i can adjust output settings on Ra304 which is conected by composite??????????
profile.country.en_GB.title
kee-lo_
I haven't got a plasma
chris_lewis
Composite video is not particularly good, There is such a thing as a VGA(HD15) connector to Scart which will give you a much better picture, however are you sure there are no PC connections on your plasma, its pretty much a standard these days.
This will also work though.
VGA to Scart
C
