HELP! Please, to view photos on Vaio Pocket
Pissy
I have copied my folders containing jpeg images from PC to My Computer/E:removable disk/VAIO Photo.. to sit alongside a folder called USER_001. When I go down this route on the PC with the Vaio Pocket (2.1) connected the folders & photos are all there as they should be....when I disconnect and look in Photo Viewer on the Vaio only USER_001 appears................Very frustrating!
2 REPLIES 2
grizedale
Instead of putting them at the side of the USER_001 folder you should put them in it (take them out of any other folder if they are in one). If you wish to create more folders for different themes of photo you can but they must follow the same naming convention USER_002, USER_003 etc. Only then will your VAIO be able to see them.
Pissy
THANK YOU Grizedale! your solution has worked......
