Help. I have lost my DVD drive!!
itu-nurse
Can anyone shed any light on this. I used vaio update after which my system crashed. I used system restore to get it up and running again, using the setting from before the update. This works fine, however, the computer no longer sees my optical drive. The drive works fine in safe mode.
It does not show up in 'My Computer' and I can not run any discs from it.
All hep appriciated.
Julie
UK
25 REPLIES 25
profile.country.fr_FR.title
@2213977901016847
blue1901, encore 5 messages, et tu deviens Vaio-fan
itu-nurse encore 2 messages et tu deviens Vaio-Fan
@2213977901016847
at least fan not groupie! a bit girlie huh?
I have V3M, it's grrrrreat but i dunno whats the difference between v2m and v3m!
C'est bien ce que je me demande aussi !
blue1901
rich912
Contributor
if you know what you are doing.
Look kid.
i am offering my solution, to transfer ur files to a network walkman means i obviously know "what im doin"!
This is the ONLY solution.
Well thanks for the friendly response! All solutions are welcome, and no one said you didn’t know what you are doing, simply that this is not the ONLY SOLUTION.
If you had read the thread you would realise that the original poster found a solution without recovering the system! A simple registry edit did the trick.
Go n-éirí an bóthar leat
blue1901
u OBVIOUSLY didnt read the "thread" my "smart" friend!
rich912
Contributor
You’re quite right; I lost sight of the fact that there was more than one problem under discussion. My apologies.
